My 06 DL650 has started having a stumble or hesitation at idle. Runs fine under a load but while idling at stop lights or just sitting, the engine will stumble or hesitate. Occasionally it will die. Starts again with no prob. 5,000 miles. Any ideas?
Thanks,
Braz, what is your idle speed(RPM) ? Maybe it dropped off a bit. Maybe a tank of bad gas ? Probably something simple. Good luck.
Stumble
Idle speed is about 1400. Just installed an Audiovox Cruise last weekend. Had not noticed this before that but everything works well other than the hesitation.
Not sure if it helps but I had a similar problem right after I installed my Audiovox. However, my bike was winterized with Stabile in the gas tank and this thing went away after 4 or 5 starts and I attributed it to the bike's system working itself out after months or non-use. It could also be that you have a leak in the pressure hoses that were connected to your Audiovox.
Wingman
Hey Braz, I had a thought about the stumble etc. Was the idle speed always about 1400 or a little lower as the manual recommends ? And does the cruise control have a vacumn control of any kind ? A vacumn leak would or could raise the RPM a bit and the lean mixture might be enough to upset the Wee. Of course I could be totally wrong and leading you astray. Keep us informed, I want to know what can upset such a nice running power plant.
There is a vacuum canister on it with a check valve. All the hoses have been checked and appear to be well seated. Weird. Please keep the thoughts coming.
Tapped screw. The air cleaner might be somethingto check. Thanks,
Don
