What is you battery voltage:
1. When ignition has been off for a while
2. Ignition turned on, lights on
3. When cranking
3. When cranking
Hi everyone well you could help me with my problem of fault finding of my (04) DL650 all started when I broke down recently was the fuel pump constantly priming since then the bike will not start so pump will not prime but I'm getting no spark the bike will turn over that is it I've replaced fuel pump all seals and O rings, kill switch spring cleaned unchecked ignition as well flasher/side stand relay is new and starter relay and I notice that my ECM was warm I was just wondering if someone could tell me does the ECM as View attachment 313948
a constant live connexion even with the ignition switched off the power is on the red and white.
thanks
hiWhat is you battery voltage:
3. When cranking
Your meter is way out of calibration.with ignition off 16.59v with it on 15.78v and cranking 14.67v its a new battery this will come down as was on charge
