How many miles on the bike?
Have you checked your chain tension lately? In my experience driveline lash (not fueling) is the biggest influence on the off-on throttle snatch. The worst I ever experienced was when I had a cascading failure of sprocket carrier bearing, cush drive rubber pieces, and chain. Tons of play all around made it very jerky.
A friend of mine described jerky behavior when his TPS failed, but I haven't experienced that failure myself.
Does your bike have preload adjustment screws upfront? If so you may be able to adjust the hammering behavior out.
