What kind of tires are on it? Are they a matching set front/rear? Sounds similar to how my old Tuono handled until I get a good set of tires on it.
Unless you're riding dirt, that is still very low. The owner's manual and build plate say 36 rear, 33 front; higher in the rear with 2-up. Some people go higher for various reasons, but I would never go lower except in soft stuff.I just aired them up to 28 & 30 respecitvely, however I recall this same handling characteristic from a few months ago when they were freshly aired up.
Not to change the subject, but I've been using the Madstad & Moose +4 for a long time and am very happy with it. FWIW.Thanks for the input everyone, problem solved, now just have to deal with the helmet buffeting/wind noise issue with the stock screen and I'll be golden. Tried all the settings for the stock and nothing worked (up, down, lowered bracket, etc.) I know it's a well-covered topic and I've already read a lot of posts on it here, and I have an adjustable clip-on extender coming in the mail tomorrow. If that fails, I think I'll try a Madstad or Moose +4.
Hey, no body-shaming.Be mindful of the weight in your trunk.
I've put about 1500mi on the bike in the last month, mostly on TN, NC, GA twisties, and have just about worn out the rear, so a stock size tire is going on soon, and just noticed that the date on the front tire is 2012 (rear is 2015 date), so that'll be changed as well. The bike does feel a bit vague when cornering still, so I'm looking forward to how the bike handles after the new tires go on. Probably going with a 90/10 or 80/20, I don't want to compromise road grip because I do love some twisties, but my other bike is a WR250R that I ride trails with often, and it'd be nice to start taking the Wee on some gravel and fire roads as well. Looking at the Shinko 705's, Metzeler Tourance, or Scorpion Trail II's.Basically, there is lots of ancedotal evidence from folks, on lots of different sites, who put wider than stock tires on the back. Most of them experienced negative handling characteristics. The general concensus was the bike was slightly harder to turn in which would quickly develop into a 'falling over' feeling. They claimed the harder to turn in felt like a tire that was worn flat in the middle from too much straight slab. The falling part... well, lets just say you have to experience it.:yikes: Most claimed that the general handling characteristics were worse than stock.
The other comment was that production engineers go to great lengths to match tire sizes with other bike geometry like rake, trail, swing arm angle, etc. to come up with good (and safe) handling characteristics. When you put a wider tire on, the entire geometry is messed up and handling in the corners suffers. And isn't that why we ride bikes? For the twisties?
That's interesting; I would expect that to make the turn-in more eager in one direction and recalcitrant in the other - yes?It sounds like your rear wheel might be slightly misaligned. The way you described it, it was exactly what I experienced until I dialed in the rear wheel better. After I got that straightened out, I raised the fork tubes 10mm but I think I'm going to try 7mm as it feels almost too eager to keep turning now.
The easiest way to tell is to find a flat straight road and take your hands off the bars and see if the bike wants to turn or stay upright. This assumes your tires are still reasonably symmetrical. It's difficult to describe, but basically it makes the bike feel 'weird' (I know that's vague).That's interesting; I would expect that to make the turn-in more eager in one direction and recalcitrant in the other - yes?
That's assuming you're symmetrically loaded. When mine does that, it's usually cuz I should have put the big water bottle in the other pannier ...The easiest way to tell is to find a flat straight road and take your hands off the bars and see if the bike wants to turn or stay upright. This assumes your tires are still reasonably symmetrical. It's difficult to describe, but basically it makes the bike feel 'weird' (I know that's vague).
