1 - 4 of 4 Posts
I am rebuilding an accident damaged DL1000 K5 and I have an 04 DL650 Speedo. Will this work on my 1000. I know the marking are different and I can have those changed but the input signals are the same right.
Discussion Starter · #2 ·
So I treid a guage from a K4 DL650. I also used a harness from the K4 not sure if the harness is different from the DL1000. It plugged right in and seemed to work well. The clutch lever on the bike is broken so I wasn't able to ride it but the rev counter seem to work accurately. The Neutral, tutn signal and hi beam light worked. The temp guage looked good but the fuel level seemed high for the amount of fuel in the bike. It may be because the bike was on it's center stand.
When I am able to ride the bike I will update you on how well it's working.
Discussion Starter · #4 ·
And it looks like the Wee guage on a Vee has even worse speedo accuracy. 7%-15%. This is my first V-Strom so it sems a little high to me.
1 - 4 of 4 Posts
