Here's mine. Upcoming this winter is to have the front header modded out from under the engine to the right side to increase ground clearance by two inches. Skid plate will be modded accordingly.
Front cylinder exhaust repositioned from under engine to R side of the engine to gain 2” more ground clearance
SW-Motech Centerstand
SW-Motech Skid Plate modified to attach to crash guards instead of engine for the 2” more ground clearance gained by front cylinder exhaust reposition
SW-Motech Height Adjustable Wide Street/Off-Road Foot Pegs
SW-Motech 15L Evo City Tank Bag with Map Case, Theft Prevention Pin, and Quick Lock
SW-Motech Side Stand Switch Guard
SW-Motech Folding Gear Shift Lever
Givi PLR Side Racks
Nissin Front Brake Calipers from a Honda CBR600
Nissin Radial Master Cylinder
Akropovic Exhaust. 9 lbs. less weight, 5 more HP
K&N Air Filter
Kriega Outback 32L Saddlebags with OS-2 Straps
30,000 hour Sementech Lo Beam White LED w/internal fan
ADVTech GPS Dash Mount
ADVTech Flood Lights with handlebar-mounted on/off switch
ADVTech Fork Brace
ADVTech Front Fender Risers
R&G Racing Rear Shock Cover
R&G Racing Crash Guards
R&G Racing Radiator Guard
R&G Racing Tank Pads
R&G Racing Filler Cap Trim
RotopaX One Gallon Locking Gas Container
ASV Adjustable Folding Clutch and Front Brake Levers
Barkbuster VPS handguards
16T Front Rubber Dampened Sprocket. (OEM 15T). Drops RPM by 250
Admore Flashing Brake, Progressive Turn and Deceleration Lighting
Oxford Heated Grips with settings control
Garmin 396LMT-S GPS- Hardwired
Rupse Tire Pressure Monitors. Rechargeable display
Kaoko Throttle Lock
Pyramid Front Fender Extender
Crampbuster
Headlight Protector
2 Locking Tool Tubes
Puig Spool Sliders
Zeta Offset Handlebar Risers
ABUS Victory X Plus Disc Lock
Murph’s Tamperproof Oil Filler Cap
Shock Socks Front Fork Covers
Phone Ram Mount X-Grip
Locking license plate storage document box
Front 22mm Axle Tool
Givi PLR Side Racks
K&N Air Filter
ADVTech Fork Brace
Kaoko Throttle Lock
Crampbuster
Headlight Protector
Puig Spool Sliders
