1 - 20 of 47 Posts
Vendor
:) Hi Everyone, DL650 and DL1000 Front Brake Master Cylinder Banjo Bleeders are in stock and ready to Ship at $19.95 all in,
Your Choice of Single or Double Banjo Bleeders in Coarse Thread for our bikes to replace the banjo Bolt at your Master Cylinder. SVRacingParts.com Go in Under For Stromtroopers on the top upper left categories, then under Brake Products, and then under Banjo Bleeders. Choose the parts you want from the drop down boxes and check out anytime you like,
Here is the Parts Guide you will want to follow:
DL650 abs Models 2007 to 2012 use the CT Single Banjo Bleeders at the Front Brake Master Cylinder.
DL650 Models without abs 2004 - 2011 use the CT Single Banjo Bleeders if you have OEM Single Line coming off your Front Brake Master Cylinder.
DL650 Models without abs 2004 - 2011 use the CT Double Banjo Bleeders if you have the Upgraded Dual SS Brake Lines coming off your Front Brake Master Cylinder.
DL1000 Models 2002- 2012 use the CT Single Banjo Bleeders if you have OEM Single Line coming off your Front Brake Master Cylinder.
DL1000 Models 2002- 2012 use the CT Double Banjo Bleeders if you have the Upgraded Dual SS Brake Lines coming off your Front Brake Master Cylinder
DL1000 Models 2002- 2012 use the CT Single Banjo Bleeders for the Clutch Side Master Cylinder to maintain the DL1000 Clutch the same way we do the Front brakes for optimum performance.
Email me Directly at [email protected] or visit me at SVRacingParts.com and I will get you looked after right away,
This is a great upgrade for your Front Brake Master Cylinder on all DL650 and DL1000 Vstrom models; Easy to Install, and the Easiest and Fastest Way to help eliminate the spongy feel that periodically develops in your Front Brake lever, and on DL1000 Models, a great way to help keep the clutch performing properly,
Double SS Banjo Bleeder
Single SS Banjo Bleeder
Let me know whenever you are ready, I will PayPal invoice you for the parts you want and get you looked after right away,
Visit me at SVRacingParts.com
Your Bike and your Brakes will thank you for installing the Correct Banjo Bleeder and using it to Bleed and Maintain your Brakes regularly,
Blair
Vendor
Blair
Vendor
Blair
Vendor
Blair
Vendor
Blair
Vendor
Blair
Vendor
Discussion Starter #7 (Edited)
Blair
Vendor
Blair
Vendor
Blair
Vendor
Blair
Vendor
Discussion Starter #11 (Edited)
Blair
Vendor
Discussion Starter #12 (Edited)
Blair
Vendor
Discussion Starter #13 (Edited)
Blair
Vendor
Discussion Starter #14 (Edited)
Blair
Vendor
Discussion Starter #15 (Edited)
Blair
Vendor
Discussion Starter #16
Blair
Vendor
Discussion Starter #17
Blair
Vendor
Discussion Starter #18
Blair
Vendor
Discussion Starter #19
Blair
Vendor
Discussion Starter #20
Blair
1 - 20 of 47 Posts
