Nice bike!
Are you sure thats rust and not dried grease? Can you scratch any off with your nail?
I couldn’t scratched it off my nail. Just brought a engine degreaser, it does not work either.Nice bike!
Nice bike!
Thanks a lot!As @nuke says, it could be something else; however, light rust on the chain and sprockets is not something I'd worry about. It's normal for humidity and road moisture to do that, even (sometimes especially) in storage. Check the chain carefully in accordance with the manual - you should have no stiff links, length and slack must be in spec, and the rear wheel must be properly aligned. Lube (as you obviously do), and ride on.
Welcome aboard!
Thank you so much! I did set my ScottOlier at minimum before. The chain looks quite dry now. I will try it tomorrow with ScottOiler (refill bottle). Do you ever get any dark patch on sprocket?That chain looks pretty dry. I have a ScottOiler too and my chain is always covered with a shine of oil. Are you sure the oiler is working properly and actually dispensing oil?
Quick test: Unbend the nozzle holder so the nozzle is free of the sprocket. Start the bike and count the drips. You'll want to see about one drip every minute, slightly more in adverse conditions.
Depending on the system, the drip frequency is influenced by the weather: The oil viscosity changes with temperature and not every type of ScottOiler compensates for this. Your vSystem doesn't, for instance. So you may need to adjust the drip rate when the seasons change.
Oh, and don't lube with anything else if you use the ScottOiler. If you think you need to lube extra, use (ScottOiler or engine) oil, not grease or wax.
Are you washing your bike with something fairly aggressive that takes the oils off? I could see how this accompanied with not riding it for extended periods afterwards could encourage condensation.Good morning from sunny Auckland,
This is my first post. Although I have been enjoying reading post from this form.
Big yellow V is my second DL after owning a beautiful black DL650 2020 LAM for 12 month. I enjoyed the extra weight and power from 1050. It suits my style of riding more touring.
Just washing my1050 this week, I have seen some rust like symptoms on the chain and sprocket. Scotoiler was installed by the dealer and it has been working well for me.
After had Covid, I haven’t been riding much and the bike only done 6,000 km since Oct 2021. It has been garaged the whole time and I don’t use it for commute.
Just wondering if anyone could help me or if you have seen something similar. The bike is still under the two year warranty. It is something related to Scotoiler?
Cheers
Ray
that is a great point. I use a bike cleaner and it can takes the oils off. ThanksAre you washing your bike with something fairly aggressive that takes the oils off? I could see how this accompanied with not riding it for extended periods afterwards could encourage condensation.
