DL1000 Hauling capacity
7806 Views 11 Replies 8 Participants Last post by  teevee
Looking at buying a used 2003 dl1000 what is the max cargo weight that can be carried.
1 - 12 of 12 Posts
The spec says the GVWR is 965lb and the curb weight is 525lb so the capacity for adding weight is 440lb. That being said, it's really a legal fiction. There are many variables to what is safe. The surface, speed, rider experience, suspension/tire changes and even aerodynamics and placement of the load all change how well the bike handles a load.
with stock springs gvw is something like 885 iirc subtract wet weight of bike 500± that give you 375-400 for rider, passenger & cargo ....
heck, I weigh 300 geared up, add luggage weight + everyday kit I was overloaded as soon as I sat on it
beefing springs is only one aspect of increasing payload, look at the weight rating of the tires, especially the rear that takes most of the cargo/pillon load
and if you want to be able to agressively ride, then think about brake improvements , do they make a perimeter brake for a 19" wheel :beatnik:
Something that I found out a few years back is that "most" motorcycles regardless of displacement have approx. the same carrying (load) capacity between 350 - 400lbs.
i.e Even a Ninja 250 has a 375lb load capacity - not much different to a DL-1000.
Gotta
Very
Wide
Rump
I think if I were to regularly ride at or above the load rating for the Strom, I would add a steering damper to prevent wobbles at speed. Otherwise, I think we worry about this needlessly.
Unless, of course, you're a duck around Christmas...
thanks! if it's not too much of a pita, could you measure the distance between the tie down loops, please? i got the overall dimensions from the sw-motech site but i'm trying to see if i can use them on my gobi bags.
btw, bike looks awesome!
That is awesome...I thought we were cool because we tied a turkey fryer and a tool box to the back of my friend's Rocket III when he won a drawing. That is rigged for touring.
It was my first ever multiday trip, so I lightened up since...
I keep forgetting, I'll try to do it tonight.
UPDATE: 11 inches in between on the side. The strings are 7/8" wide.
1 - 12 of 12 Posts
