1 - 6 of 6 Posts
I just installed Sonic Spring in my DL1000's forks. I had to tighten the preload adjuster all the way in in order to tighten the nut under the fork caps. Now I can't move my preload adjusters; they are all the way in. Any suggestions?
Discussion Starter #2
Never mind; fixed it.
You hung up the bottom of the adjuster on the spacer I'll bet.
Nope. The preload adjuster was bottomed out so tightly that I needed to remove it again and use a vice to get it moving again. I usually seem to have a little adventure whenever I work on my motorcycles.
Glad you got it...:thumbup:
1 - 6 of 6 Posts
