1 - 6 of 6 Posts
The dealerships have no part number for any of the parts!?
The bolts/pivots/springs etc.
NOTHING appears on ANYTHING the dealers have !
AND no part number for the cooling system drain plug sealing/crush ring !?
Suzuki accessorie catalog part # 42100-06851 $269.95. Your dealer is obviously braindead. I'd look for another or buy one on-line.
Whoops!
Sorry. Can't help if you're just looking for center stand parts. I thought you might be looking for the whole assembly which is probably the only way to get the parts. A bike like the Strom should come with a stand as original equipment.
Been there, done that...prts are orderable, but typically long lead-time.
I've found the folks at cheap cycle parts . com are very helpful, anytime I've had a problem I call and they have the answer in a minute. I'm sure most of the OEM vendors are good. Good luck.
You can get the springs you need from Suzuki, I just ordered and installed them, they're perfect. They're just not under the DL1000 parts list. Order the following part numbers:
09443-14059 and 09443-22013
Roughly $12.00 for both including tax at my local dealer.
1 - 6 of 6 Posts
