1 - 2 of 2 Posts
Hi. Does anyone here know how valve adjustments are performed on the DL 650? Shim in bucket, Adjustable screw tappets, Also I was looking at the DL 1000 member sites and noticed alot of talk about members replacing Clutch baskets to rid their bikes of a noise and or shuddering they experience at low speed and idle. Was just wondering if the DL 650 uses the same component. If anyone out there owns an SV 650 have you experienced any problems in this area? Any info on this would be greatly appreciated. Thanks
Valve adjust DL650
Should be shim under buckets. Clutch basket is only a problem on some of the DL1000s. I don't think the DL650 should have the same problem. I have not heard of it on the SV650s.
1 - 2 of 2 Posts
