1 - 3 of 3 Posts
I have a problem, bike was runing [fine] turned it off to change oil an filter. After I was finished I could not get the bike to start. [have spark] checked fuel pump relay, failed one of the of the two tests. Has anyone else had this problem?Will order a new one tomorrow but your never sure on electical problems its a 05 with 50K miles on it.
Living the Stereotype
Check the clutch safety switch connection near the clutch lever.
The clutch switch and other safety switches won't allow cranking. The usual suspect is flooding in hot weather. Try opening the throttle.
1 - 3 of 3 Posts
