41 - 45 of 45 Posts
If you need a plug and play solution, look near the bottom of the following page for an adapter to use a heavy duty switch.
VStrom
If you are comfortable with wiring, do your own to extend the wiring to a switch after separating a connector on a red wire near the positive battery post.
If you are very comfortable with digging into the bike, see Proper ABS on/off switch
It is for a 2009 but the wire color is the same, the mod only needs a light duty switch and ABS can be restored without turning the ignition off first.
Well it seems that link isn't working any more :( .. are there any other sources? does it work on Gen2?
EDIT: Never mind I found the answer.
The page is working now.
Hello!
Found this old thread regarding to adding a ABS switch for turning it off for off road.
Now since I only have SOME ability to work with electronics and try not to splice into any wires if I can help it, I opted for the plug and play option from what GW posted.
However, when I clicked into the page and follow to the "New DL" page, I do not see an ABS switch listed.
The older Vee has it but it is listed as "not for new DL".
Am I just not looking at the right spot or I am hoot with this option with the newer Vee?
Thanks in advance,
For the new DL?
Mine is a 18...pretty sure that classified as "new".
What year is your Vee, good sir?
41 - 45 of 45 Posts
