1 - 11 of 11 Posts
so, cut out on me this week. flashed F1.
I tested the battery and it was marginal, just over 12v. Put a new one in and still no start.
When i push the starter it just clicks, nothing else. At first it would turn over but now nothing and a good 13+volts.
Any ideas?
The headlights come on ok, no fault codes.
So it's no longer flashing an FI? 13+ volts isn't meaningful. A good battery will read 12.5-12.8V unless it's showing a surface charge. Check the wire terminals, especially at the starter motor and solenoid. A new battery should be put on a charger before using it to start an engine.
Discussion Starter · #3 ·
battery charged
when i hit the starter button the battery drops to 6v, sounds like a relay or solenoid is clicking under the seat area.
That indicates a weak battery or a bad connection. It's throwing the starter relay but doesn't have enough power to spin the starter motor.
Discussion Starter · #5 ·
Leaning towards a bad starter. I put power to it and not much happened. Just barely turns. I have removed it and will take it to a rebuilder
Same thing...
I just had this sort of thing happen to me.
Checked the battery. Marginal, so I replaced it.
Checked starter relay. Was OK.
Checked starter switch. Was OK.
Checked clutch position switch. BINGO!
Cleaned switch. Packed with dielectric grease.
Now Freya is a happy girl again. So am I. :thumbup:
Where did I put the bong now?
It's not Digger's situation though. A clutch switch problem would not allow a click.
$Whatever$
And that's worse...........
1 - 11 of 11 Posts
