Think safety first. A broken chain can wreck your motor or throw you to the pavement at speed. Any good 0 ring chain is better than a kink. Grab the bad link with slip joint pliers. Twist the bad link to make it straight. If it feels crunchy, you are on borrowed time.
Some brands do not have screw swaged master links. If you need that, EK is the likely vendor. RK is also top tier.
At 100 HP, a 530 is not required . I prefer Suzuki CS sprocket. Sun Star or JT rear at 43 or 44T as factory 41 is redickulusness. Make adjustment for bigger rear sprocket. I order 120 links and cut to fit.
I replaced my DID Xring chain % sprockets yesterday. 20K miles. Saw one kink - until I removed it. Had many more on the garage floor. Junk. Clatter noise that 650s exhibit is gone.
Vinnie repaired his new chain and saved his adz. Vinnie knows when to replace his kinked worn out chain with a new one. Thank you
