That's great. Do you know what type of plastic it is? I wonder if results are the same across types.
What he said. You can count on any decent acrylic being restorable. Poly, not so much. Unfortunately, nearly all DOT compliant windshields (this includes OEM and half of the Givi Airflow) are polycarbonate, because it is shatter resistant. Acrylic usually isn't - it can be made so, I hear, but only at great cost. (Calsci is one company that claims to make shatter resistant acrylic windshields. Madstad hints at it but doesn't say directly.)Both acrylic and polycarbonate ( and yes even glass) can be polished. BUT.....if it has a scratch resistant coating ( most polycarbonate products have to have this) polishing can lead to ruining the screen. Once you break through the coating you have a and edge that is usually quite obvious and there is nothing you can do to fix that.
nope. as an eyeglasses wearer, I wouldn't recommend that. optics are a completely different level.Think it works on eyeglasses with fine scratches?
It could, but what would happen to any coatings for uv, astigmatism etc?Think it works on eyeglasses with fine scratches?
A Givi brand screen.That's great. Do you know what type of plastic it is? I wonder if results are the same across types.
