I would never have anything that does not run through a switched source.
If your going to add other stuff just add a fused relay, Mine is zip tied on the frame rail and activates off of the license plate light. its like under $10. If the forum has said anything its that the electrics are WEAK over long term ownership.
I am also adding relays for the headlights , maybe just the low beam thats on all the time.
I think I will look into making a voltage sensor over the winter
An LED would light when there was more than 13 Volts. It would just say you are or are not charging
Just a little hole with the led pocking out.
