Hey, gang..
I'll be attempting to cut into the dash to install the waterproof USB Power Socket I linked to earlier (see below):
BurnsMoto - Motorcycle USB Weatherproof Power Socket - USB Charger with optional SAE to USB
I was thinking of housing it on the left side dash and doing so would require three holes to be cut. Two of them for the actual bracket and the third for a rubber grommet. This third hole would allow the wiring to run under the dash and to the battery. I would then cover the unsightly red & black wires with a loom or something..
What's the simplest and cleanest way to make these cuts? I'm thinking a Dremel with a some kind of a router bit or something similar.
Alternatively, given the kind of bracket, what other alternative solutions can you think of? I'm not the creative type when it comes to mounting locations and I would like to go for a cleaner look...
