1 - 10 of 10 Posts
Got my new to me 07 wee back in August and have finally gotten around to putting a top box on. I had read online about people using hdpe cutting boards to mount pelican cases on their Stroms and my curiosity was piqued.
I ended up with a 1/4in thick Walmart board. The one I got had that little channel cut around the edge, so I put that facing down to mitigate dirt or water collecting. I used flathead m8 screws and countersunk them into the surface of the cutting board and then bolted it on from the bottom. I had to do this all with the OEM rack detached from the bike. Be sure to cut holes in the board to accommodate a deep socket for the 2 rearmost rack bolts! The nice part about using m8 bolts is that I found the nuts to be the same 13mm size as the bolts for the OEM rack which is a nice feeling. Since the oem rack is no longer flush when you remove the rubber insert, I put two washers on each bolt between the bottom of the cutting board and the top of the rear rack. If I didn't do this I would get a concave flex in the board as I tightened down the bolts.
Wheel Tire Automotive tire White Motor vehicle
Then came the case. I nabbed a pelican 1520 off eBay. You can see I offset the cutting board to the left to avoid the exhaust and still have the handle accessible.
I aligned the box on the board and taped it down. Then I shot 4 pilot holes through the box and board at the same time, drilled them out to the correct size and then installed some m8 buttonheads inside the case with a fender washer and a rubber washer each. Very happy with the result!
Wheel Tire Vehicle Automotive tire Motor vehicle
I did end up putting some pilot holes through the case that I couldn't use.. so now I have to find a way to plug those up.
Automotive tire Font Gas Auto part Electronic device
All in all I found this to be a fun process. I can report that the box is still very sturdy. It does feel a little smallish but I can still fit my messenger bag in for my commute to work. I can also dice vegetables at the campsite now too, which is a bonus ;)
Nicely done. I have a similar box mounted a little differently but I love having that thing back there. It's really waterproof and secure. Holds a lot of stuff and makes a good platform to strap even more stuff to. Best,DD
What's the point of bolting the Pelican case to the cutting board? Why not just bolt the case directly to the rack? 1/4"-thick UHMW seems kind of flexible to provide much support for the case.
Might as well go full KLR 😁
Reactions: notacop
Using cutting board is nice but I'm not sure it's necessary to add to mount a box. I've got the Suzuki steel bag frames on my 04 Wee. When mounting a pelican like case to the frames I bent a couple bits of strap that would hook over the bottom rail that bolted to the cases and used the holes that used to hold the top bag latch to run a clevis pin through. I used 1/4" fender washers to spread out the load on the mounting bolts and haven't had a problem in 10 years.
I've seen some really well made mounts but are basically a work of art and really overkill.
The Hardigg box I used one the rear rack I just used a U bolt and a couple straight bolts and a bit of strap to connect to the Suzuki frame. I don't normally remove the luggage so hard mounts work for me.
I didn't try to avoid the muffler when positioning the top box. It's more than far enough from the muffler to worry about.
2009 DL1000
I like how your project turned out. I recently went through a similar process on my vee. I bought a huge dry bag and wanted a plate to help support it when full, but mostly when empty. I used 1/4" plexi glass to get the size I was after and have a clean look. These projects are always fun.
1 - 10 of 10 Posts
