Good job on doing that
it probably need some more smoothing and maybe just to hit the edges with a torch flame to get them clear and transparent. Wondering did you explore the option of using polycarbonate instead ? How much more expensive is polycarbonate ?
I am guessing you warmed up your pieces in the kitchen oven ?
My limited knowledge on plastics and some research is suggesting "lexan, perspex and other acrylics are prone to yellowing and cracking producing sharp edges when broken?
I guess in your application the pieces are small and they would probably break off and fly away, so no danger of cutting yourself. What tool did you use to cut it ?
I tried to cut my bike windshield once with a scroll saw and very fine blade, but the cut was melting behind the blade and welding the plastic back together, so I picked up a special blade for plastic and it did a much better job.
Here is what Google returned on the two:
Perspex® acrylic sheet can resist impacting 17 times more than glass whereas polycarbonate can manage to resist impact 250 times more than glass. ... Acrylic is more rigid and can crack under extreme impact.
