1 - 20 of 30 Posts
Just wondering what your ideas are on Kaoko Throttle Lock Cruise Control For Suzuki V-Strom 650 '2010 With OEM Handguards
Interested to know if you've had one used one or have one for sale
Many thanks in advance,
the drifter
A throttle lock is not technically cruise control. Throttle locks work great if you are on a flat straight stretch of road. If there is any grade up or down with a throttle lock the seed will not stay constant.
The good news is throttle locks are cheap and do work at allowing you a few moments of relief.
I have Kaoko's on both my BMW but only because they came installed from the previous owners. I would not spend that kind of guap when there are other throttle locks that work just as well for less than $30.
Hi Tim,
I've got a throttle lock on my 650. I don't know if it's a 'brand name' but it works. As 'Perazzi' noted, they don't hold the speed on hills, but if you want the opportunity to set the lock and rest your grip for a few minutes on a straight-away, then they work fine.
I rode 17,000 kms this spring across the USA and found it very handy just to rest your hand and wrist for a few minutes. 99% of the time I'm a two handed rider!!
Later dude....ride safe.
Larry
I have other throttle locks and IMO the Kaoko throttle lock is worth the money, I have it on a 650 with the Barkbusters handguards.
I've been thru several lock type "cruise controls".
I've tried to use the NEP but I didn't have a mechanical engineering degree and could never get it mounted right and gave up. Tried the Go Cruise and Omni-Cruise and both started to slip after a time and I had to cut back on the grip puppies to fit, but at least I could install them. :smile2:
Finally got a Kaoko. A bit spendy but easy to install and holds. It is a bit fiddly to set and takes some practice and getting use to. But it holds. It is not a cruise control though and needs to be adjusted (as all locks do) as the terrain changes but the friction is just enough to make it easy to do and still hold the new setting.
I've had the Kaoko about 6 years and still works fine and gives my throttle hand a rest as needed.
One Kaoko installation note: after installing the Kaoko I found the compression bolt head lying on the garage floor. It had snapped off. I did not think I had torqued it down that hard but maybe.... I picked up a steel bolt from Ace Hardware and it has performed fine. The original bolt was passed on to Twisted Throttle (where I purchased it) and photos sent to Kaoko. The thought is it is/was just a fluke, a manufacturing flaw in the bolt.
YMMV
My bike had a KAOKO on it when I bought it. I never liked it. Too fiddly. I adapted a cheaper one that mounts next to the throttle cable housing, quick & easy to use. Sold the KAOKO for $40.00.
Wow.... Really appreciate the input.
I realize they're not cruise control but just a throttle lock.
They do seem a bit on the expensive side, but then again on a long journey it would come in handy for that short rest the wrist.
I do have a trip planned for 2020 consisting of 18000 km.
I'll keep my eyes open for a used one or if any of you fine gentlemen happened to come across one before I do please let me know I would like to give it a try.
Here in Northern Ontario it is almost time to put the bikes away till May of next year so far all my Southern friends if you are riding this winter ride safe and keep the rubber side down.
Tim
the drifter
Short rest is exactly what it will provide. I drove 5,000KM with it on my 650. It drove me nuts... I had to adjust it thousands of times because there were few level/straight sections of roads. However, it did allow me to rest periodically, which is pure gold.
For slabbing, nothing beats proper cruise. You'll realize that the first time you ride with someone who has it.
Had a Gocruise on my Strom. It really helped to relax your hand but you can't set and forget. It's adjustable with a thumb screw to compensate for wear and slippage. Had to trim the grip puppy down a little and heat the OEM hand guard to pull it out a little to clear.
Discussion Starter #13
I found a fellow in Wisconsin that has an atlas throttle lock and I messengered to see why he's selling and what he's asking.
From looking at the website there appears to be two different models one that goes on the upper portion of the handlebar and one that hangs down from The handlebar.
Thanks for the tip about your friend that's got one and likes it
I've had an Atlas for about five thousand miles now. Overall I'm happy with the price vs. performance and design. Engaging it doesn't have a good solid feel because you're compressing a silicone pad against a flexible surface, but it works.
The only thing that took a bit of getting used to is that it's between your thumb and starter switch. It took a few rides to get used to going around it when hitting the starter switch.
Ditto on the GoCruise. So simple and easy to set. Looks a little goofy at first but then you don't even notice it except that the ease of operation is so simple you just shake your head.
I have had a kaoko - Never could install it properly
Vista Cruise - Would not hold with adjustments
Atlas - Also would not hold despite adjusting over and over
I now have a Go Cruise that is easy to install and easy to adjust.
Once I win the lottery, I will install an McCruise. There's no substitute for a true cruise control instead of a throttle lock.
FWIW, I've had a Rostra CC on my '08 for several years now. Works very well and has given me no issues whatsoever. Those very long days are MUCH more tolerable because of CC being able to drop my right arm for a while and not need to adjust every time the road goes up or down. They are fairly cheap to buy, and I followed directions others posted here. If you are up for it, this is what I'd recommend.
While I think the Atlas is ugly, the fact that it takes up no grip space makes it worth considering. This is another reason why I like the Kaoko and Throttlemeister, both of which look much better than the Atlas. I used both the Kaoko and Thottlemeister on various bikes for years and liked them both quite a bit. I have manly hands and like having access to the full width of my throttle grip. I'm not sure how either would work with the OEM handguards though. Also since they are now your bar end, if you drop your bike on the right side, it may damage them.
That said, I've also used a few versions of the Vista Cruise for many years which I liked very much. I'm currently using the newer version of the GoCruise on longer trips and during my last 7000km trip to and from Deals Gap it worked really well and held my speed extremely well, with the exception of steeper inclines/declines. Once in the mountains, I take it off anyways and enjoy the roads, as I ride too assertively on those roads to need one. I also have the original version of the GoCruise, but have never used it.
As mentioned, having an electronic cruise control is the way to go if you are planning on doing some serious distances on a semi regular basis.
That Atlas is $135 !! It just looks like a fancied up NEP. For an extra $110. I have the NEP ones on all my bikes and they work great.
Do a google search for NEP Cruise Control. It appears I dont have enough posts to post a link.
1 - 20 of 30 Posts
