On the way home it started to rain so I went to zip up my sleeve to keep the water out. I rarely turn on cruise control, but I tried today so that I could zip my left sleeve. The cruise light came on, but when I hit the "set" button it wouldn't kick in. The dash CC flashed but no CC. I started to think that maybe the 1050 thought the clutch or the brake was being pressed. Once I got home I checked the levers. I also checked to make sure the brake light turned on. When pressing the front brake the brake light came on, but no light with the rear brake. These things might be unrelated, however I assume that the computer knows that it isn't getting a signal from the rear brake lever so it won't allow CC to engage.
Does anyone have a suggestion? The rear ABS works so the rear braking system is getting some signal.
