It most certainly has to be this, kinked links, or the axle moving.Make sure the bike is in neutral, if it's in gear the chain slack can be taken up making it seem too tight.
What he said, for sure. If not the case, then put it up on the center stand in neutral and loosen the tension until you can check for links that are stiff. If you see any red powder (rust) where the rollers meet the links the chain is near finished. If not, oil the chain and check it again for kinks again. If you can't easily work a kink out the chain is probably finished.Make sure the bike is in neutral, if it's in gear the chain slack can be taken up making it seem too tight.
My personal opinion would be, not to use a wire brush for cleaning your chain. I believe that the stiffness, and sharpness of wire bristles may cause premature o-ring failure on the links of the chain.I clean and lube the chain frequently (use WD40 and a wire brush to clean and have a Loobman oiler installed).
New to the wee, so I'm not sure about the geometry, but my understanding was that being unloaded on the centerstand changes the sprocket to sprocket length. I'd think you'd need to have more slack on the centerstand than on the side stand.In spite of what the owner's manual says, if the bike is equipped with a centerstand, always check chain tension with the bike up on the centerstand. This will allow you to spin the rear wheel, (with the transmission in neutral), and check for different tensions, at different places, and also inspect for any abnormalities.
Yes, you are correct, and that is how I adjust my chain; with more slack on the centerstand.New to the wee, so I'm not sure about the geometry, but my understanding was that being unloaded on the centerstand changes the sprocket to sprocket length. I'd think you'd need to have more slack on the centerstand than on the side stand.
Agreed. A stiff or stiffer 'toothbrush' or a little bigger. If I have the rear tire off I give it a good bath in kerosene by letting it lie down off the front sprocket in a long dish of it and moving in about six inches at a time. My lube is Dupont in a small bottle something.My personal opinion would be, not to use a wire brush for cleaning your chain. I believe that the stiffness, and sharpness of wire bristles may cause premature o-ring failure on the links of the chain.
All of the chain cleaning brushes that I have seen are of a synthetic type, (nylon), and not wire/metal.
The danger is greatly exaggerated. I wouldn't have a problem with using it as a cleaner. It's a poor lubricant for high pressure applications like chains though.Be careful with the WD-40. It can get past the "o"rings and clean the rollers, but no oil can get back in.
I used to do this as well to my chain; gave it a bath in kerosene. Doing so seemed okay because it reminded me of cleaning bicycle chains when I was a kid.Agreed. A stiff or stiffer 'toothbrush' or a little bigger. If I have the rear tire off I give it a good bath in kerosene by letting it lie down off the front sprocket in a long dish of it and moving in about six inches at a time. My lube is Dupont in a small bottle something.
