1 - 4 of 4 Posts
I want to remove the brackets that formerly held the Vee plastic lower guard. I just want to de-clutter. They are held by crankcase bolts. The service manual recommends 11 Nm for M:6 and 26 Nm for M:8 crankcase bolts. I expect these bolts are M:6 but I will measure the diameter after removing one. Before I mess anything up, does anyone have any input?
They are M6x1.0. If you use a torque wrench, keep your head in the game. A badly calibrated, wrongly set or too large a capacity torque wrench can wreak havoc with small bolts. 84 inch pounds on my little 200in-lb torque wrench is what I use on 6mm shank bolts on critical areas like camshaft pillow blocks.
1 - 4 of 4 Posts
