1 - 4 of 4 Posts
So I have a Corbin on loan to evaluate, and I can't get the :furious: thing to sit down on the frame. It won't clear the DL luggage rack casting. It seems to need to slide about 1/4" farther forward into the tank, but it won't. I tried to fit it with and without the latch pin plate.
The seat was originally on a 1000 which wrecked, but I don't se any signs of damage. It is definitely not twisted.
Ideas?
Glenn
Later model DL650s have a coolant reservoir under the rear of the fuel tank that the older Corbin seats hit with the leather covered slats in the front. Those slats need to be shortened. Also, the wire helmet holders under the seat were moved in 2007 and older Corbin seats have rubber blocks that hit those wires. They may need to be cut off.
Discussion Starter · #3 ·
Yet again... Thanks, Greywolf.
Glenn
even with removing the items under the seat, the older corbin does not fit very well at all on the 07+ bikes, just a forewarning before you start ripping up the bike. I learned the hard way
1 - 4 of 4 Posts
