Ok, I am a wrench guy who loves tools. I made my living with tools and teaching other people how to do the same. So, if there is a slick tool out there that helps, I WANT IT! (ask my wife!)
Two recent additions to my formidable collection got used today while working on the Wee installing some heated grips. (That's another story...) These are Harbor Freight tools, mind you. Snap-On and others make "Professional Models" of each...for much more money. If I were still working in a shop and used these a lot I would pop for the better ones. But, for my home shop these are just perfect.
1) 20 Amp Automotive Circuit Tester (#67725).
20 Amp Automotive Fuse Circuit Tester
This is the Cat's A$$ for checking current draw on circuits. You just pull out the fuse in that circuit, plug said fuse into the side of the tester, plug the tester into the socket you just pulled the fuse from and turn it on. You will get the reading of the circuit's amp draw. Used this on my new heated grips to see how much power they actually took and how they were cycling with the heat controller. Slick! Well worth the price. I got it on sale or with 20% off or something. Around $10. Some may like their DVOM for this task but having worked in the field for many years I appreciate the fact this thing plugs in like a fuse and doesn't harm the socket. Also, if you should blow the fuse, big deal. It takes standard automotive fuses that are cheap and easy to get.
2) Digital Battery Tester (#66892) <$69 on sale or find one of those 20% off things>
Digital Automotive Battery Analyzer
You have batteries. In your car, your truck, and you bikes. They wear and go bad over time. You hate it when they die and leave you stranded. BUT, that doesn't have to happen. With the proper tests you can know well in advance when that battery should be replaced. Now, some failures are impossible to predict, things like an internal connector break, but these are fortunately rare. Most problems can be caught well in advance...IF...you have the proper test equipment.
This type of tester has been out for some years now. When I was a technical guy back at GM in the late '90's we were requiring dealers to use these to verify bad batteries. In fact, you would not get paid for a warranty claim if you did not verify battery condition with a similar type tester. They are the standard modern battery test, and for good reason.
This type of tester can alert you well in advance of a typical failure. You can read all the technical stuff on this elsewhere (pages and pages) but the simple explanation is that it electronically runs several internal tests that tells you how well the battery is actually working. It will tell you the CCA of the battery and tell you what percent of the battery plate area is still viable. From this the manual explains when to "pass" and when to "fail" the battery.
It works. I had a rare starting issue on my Wee. Once or twice it failed to crank over properly. I didn't know if it was a fluke or if their was a real problem with the starter, battery, or switches. A 30 second test with this tool showed the battery was 60% gone and should be replaced.
Fast, easy, accurate. I love it! Since we have two cars, two bikes, a riding mower, two kids with cars, not to mention other family members and friends who come to "Mr. Fix-It" for answers I picked one of these up. It makes my life easier not having to guess when something is going to fail next. Plus, it saves me money as I know what really is good and what is not.
