no
check your stock wheel bearings if ok
place axle between 2 saw horses
use tape weights and masking tape as temp spots
slap it to break static friction
crack pot theory still under test for 40 years
That won't work.
The center of gravity of the tire/wheel will be too high...
dyna beads work great. I have them in all my bikes. Speeds over 100MPH no problem and you never need to re-balance. That's my 2 cents worth.
Discussion Starter · #5 ·
Seems like you could balance on bike w/o stands in that case. Front splay calipers for free movement and rear re-insert axle w/o sprocket / spacers.:confused:
How much do "Dynobeeds," cost:confused:
