You don't happen to have a throttle lock on the bike do you?
I used to think that the throttle cables were the same as clutch and did not need lubrication, but I was told by an administrator that the throttle cable do require lube. I have not yet lubed my 2008 however.Does the throttle tube move smoothly on the bar? It needs to be absolutely clean. If you want to lubricate it only use a light DRY lube. Anything else will collect dust and gum it up again in no time. Same goes for the throttle cables, they are NOT supposed to be oiled. Ever. They have teflon liners and any oil will collect dust and grit and end up seizing the cables.
BEFORE you get that deep ... Try "relaxing" the screws that hold the switch box halves together while the throttle is stuck wide open. You can see where I'm going with this. Remember that there are two cable barrels that rotate in the throttle tube flange. They can get scummed up and even might even have a frayed/broken wire strand.Greetings all. The throttle on my DL650 K4 ... I'm thinking next step is might have to be tank removal and throttle body butterfly inspection.
Ditto Dark Angel. Lube the barrels but not the cables.Does the throttle tube move smoothly on the bar? It needs to be absolutely clean. If you want to lubricate it only use a light DRY lube. Anything else will collect dust and gum it up again in no time. Same goes for the throttle cables, they are NOT supposed to be oiled. Ever. They have teflon liners and any oil will collect dust and grit and end up seizing the cables.
Yes, the barrels at the ends of the cables, the cast lumps of metal, need a little grease where they attach. Once you put any oil inside the cables you will have trouble. They're teflon lined and don't need oiling. If they're binding it's time to replace them. The clutch cable is the same.
Take the throttle lock off and try it again.Greetings all. The throttle on my DL650 K4 will stick at whatever point I let it go. I.e. if I twist back to WOT and let go, or anywhere in between that and idle, it will stay there when I take my hand off. The bike has been sitting for a while as a Goldwing and an XT have joined the tribe and get much of the attention these days.
I have verified that my bar end weight is not too tight, the grip is not pressed against the switch mechanism, and my throttle lock is not binding at all.
Today I did the tank lift and got a little WD on the underside ends of the cables on the little springs but no change.
Can anyone advise on likely culprits for the stuck throttle, remediation, and lubrication suggestions. I'm thinking next step is might have to be tank removal and throttle body butterfly inspection. My understanding is that the cables themselves are not to be lubed as they are Teflon coated inside.
Thanks in advance,
HW
