Update - Removing the suspension took a couple of hours, taking it slowly and with a few glitches. Really, the thing that took the most time was figuring a way to hold the rear of the bike down.
If you don't have the shop manual - get the manual, as it includes photos and torque values for all bolts, as well as the procedures to follow.
Also - and this is a generally good shop tip I got from a service manager - have on-hand a box of small Ziploc baggies and a pad of Post-It Notes.
Each time you perform a step in the instructions, put the parts in a baggie, and put a note in or on the baggie indicating what they're to, what size sockets or wrenches you need to reinstall them, and whether the nuts were on the left or right side of the bike. That can save some time and frustration. Then put the baggies in a bin, so you don't kick them all over the garage, scattering both baggie contents and Post-It notes. (Guess how I learned that last one...)
I didn't need to remove any body parts (mine or the bike's) to pull the suspension, save the front fender.
Specific notes on the rear shock removal:
- If you place a jack under the swingarm, it will help to keep the rear wheel from banging down on the ground when you start unbolting things.
- You don't need to remove the dogbone, just the lower bolt. The dogbone can then pivot down and back far enough to let you get to the lower shock bolt.
- The hose for the preload adjuster is held in place by a small clip; you need to free it before you can remove the shock.
- You need long extensions to get sockets to the shock bolts, particularly the upper mounting bolt.
- You can use a long wrench to brace against the centerstand cross brace (Suzuki OEM in my case) when trying to break loose the lower bolts. For reinstallation, a helper might be advisable when torquing things down.
Specific notes on the front fork leg removal:
- The easiest way I found to take weight off the front wheel - barring a steering head stand or an overhead lift - was to run a tiedown from the luggage rack to heavy things (boxes of books in my case).
- Using a jack under the oil pan just tilted the bike onto one or the other of the centerstand feet, but didn't lift the rear wheel.
- The front fender is fairly well trapped by the forks; it's much easier to remove after starting to slide one of the fork legs down
- Make sure to remove any stickers or decals (e.g. state inspection stickers) placed on the fork legs between the upper and lower triple clamps. Even with the clamps loosened, it's a very tight fit; the stickers will be shredded and you'll be annoyed.
- A jackstand at full extension proved a convenient way to support the front brake calipers after the wheel, forks and fender were removed.
Finally, a bit of advice from Jay @ Sasquatch - a rifle case makes a dandy way to pack the shock and forks for shipping.
Good roads,
- Lewellen180
