complete front light led conversion kit ?
2127 Views 8 Replies 7 Participants Last post by  inouk
Hi everyone,
has anybody done the job ?
Cheers
1 - 9 of 9 Posts
Plenty have. Try the search feature. Beware highly inflated light output claims. The very best (US made CREE elements) make about 100 Lumen per watt. Many claim more.
Hi everyone,
Cheers
If I am understanding you correctly, do you mean changing out the whole assembly for the dual LED headlights in the 2022 DL1050? That would require the 1050's fairing and other associated hardware. It would become quite an expensive undertaking!
Might want to check out this post I made about installing some LED bulbs.
No idea about longevity, but the light output is a bit better (and far whiter) than stock and no glare to oncoming drivers
Dusty
The 2014-19 1000 uses the same headlight assy so you can check that forum for LED recommendations too.
I used Auxito LEDs in mine....but had to buy 2 pair since LEDs were H7 & H9. Still....at $65-70 for both sets...then selling 1 set here..left me spending $35 for my H7 H9 set.
&...They work great.
Guys, look at the wording of his topic, he wants a whole led assembly, similar to #1 in the diagram below, only integral led(s). not just replace the halogens in the existing OEM housing. There are LED & HID conversion kits for many makes of cars and trucks, and I gather that he's looking for something similar for his 'Strom.
Font Circle Auto part Drawing Pattern
Maybe not, but with the widespread availability of plug n play LEDs to replace halogens, surely he is aware of where to buy led H7's & H11s.
See less See more
Reactions: 1
Assume looking for this:
Automotive lighting Font Helmet Automotive fog light Headlamp
See less See more
Reactions: 2
The problem with this one is that there is no possibility to adjust beam
And connectors are vey thin
Envoyé de mon iPhone en utilisant Tapatalk Pro
Thanks to everybody. Founded the unit below from a Danish company.
Cheers
Assume looking for this: View attachment 304958
[/QUOTE]
1 - 9 of 9 Posts
