1 - 19 of 19 Posts
20 DL1050XT
I'm super lame.
I don't own a test light or a ohm meter or whatever.
Installing switched power to GPS and using the switched accessory plug behind the right side of the radiator, commonly referred to as the heated grip plug.
Two wires: light blue and black
Common sense would dictate black is ground, making light blue positive. But... I've been burned before (not literally) using common sense to assume wiring colors.
I've searched....a lot... Can anyone tell me which wire is which? I guess I'll go buy a tool if I have to... I should probably own one anyway...
This is the wiring, after cutting off the plug and attaching Posi Locs:
Motor vehicle Automotive tire Automotive lighting Hood Bumper
Queensland, Australia
Light blue and black. Heated grips and accessory wiring. Black is earth.
20 DL1050XT
Discussion Starter · #4 ·
20 DL1050XT
Discussion Starter · #5 ·
Spend $20 on a meter.
Comes in handy working on a motorcycle.
Yeah... I'm embarrassed that I don't. I do a surprising amount of electrical tinkering (I'm a HAM, even) and I just have always found a way around using one. Thanks... :)
<snip> I don't own a test light or a ohm meter or whatever. <snip> I've been burned before (not literally) using common sense to assume wiring colors. <snip>
I've tested your sentences above and can confirm they are connected :)
20 DL1050XT
Discussion Starter · #8 ·
∆ Checks out
Reactions: Brockie
20 DL1050XT
Discussion Starter · #9 ·
Any pic. Of plug before you cut it off? Or sitting on the work bench.
No before pic. I'll get an after pic when I get home. It's the open connector on the same bundle as the horn, you can actually see it and grab it (just barely) by looking at the horn from the front. Held to the horn wiring with a white piece of tape.
On a more serious note than my other comment, does anyone know what this part of the loom is rated at - could I run LED DRLs and a 5 amp sat nav feed from it?
20 DL1050XT
Discussion Starter · #11 ·
From my searching it appears it's only safe to use at about 3A + max, so it'd be a good trigger for a relay to run that stuff, but not for power for both.
Reactions: Spark
20 DL1050XT
Discussion Starter · #12 ·
I'm thinking that your 5 amp SatNav is in reality 5 volts. The draw should be more 1 - 1.5 amps.
Its on a 10 amp fuse I believe which should easily handle a pair of LED spots and a SatNav. Heated grips would have a far greater draw.
Yeah, I thought it was odd if it was rated at 3A, as I'm sure grips would draw more. I'll check the rating on the sat nav again.
Just for my future reference; is there a way, or plug etc. to tap into that connection?I’m assuming the (non power) side is just a PLUG THE HOLE THING?I want to plug into the power side.I’m asking this (with-out) seeing,or looking at my bike.Lazy mans mechanic!
20 DL1050XT
Discussion Starter · #17 ·
Eastern Beaver makes a connector but they are unsure if it mates with the "new" Strom:
Correct that the nonpower side is just a plug.
Obviously my electrical knowledge may be suspect since I don't own a multi-meter :) but I'm confident that something like PosiLocs is a really efficient way to tap this circuit. If you have small hands you can even do it this way without removing any plastics, save for the inner lining which is held on by three push-pin connectors. You can just pop the pins, shove the liner out of the way, and do your business.
The siting of that plug is surely a mystery. Older models featured the same plug as is used for the horn - but that one is different although I have seen it before so it must be available somewhere. Auto electrical parts store?
That Eastern Beaver link looks spot on.
"New DLs Aux Power Adapter $12.95" at the bottom of the page.
1 - 19 of 19 Posts
