If you are ok with minimal protection, there are some good options that are designed for winter bicycling. Hippo hands with heated grips and MC gloves seem to offer the best combination of safety and warmth.
Depends on the gloves. Plenty of "MC" gloves are useless in a slide too. My downhill ski racing gloves are more protective than any MC gloves I own. That being said - I don't care. Don't crash, if you do turtle onto your backplateSnow gloves won't fare well on asphalt me thinks.
so no problem getting your finger caught under the lever?Have a set of the army trigger finger ones, they're pretty decent but it seems that air ends up flowing through the tops. Snowboarding trigger finger gloves are really nice but they typically are pretty pricey.
I just adjust the brake out to it's farthest setting and don't have an issue. The only problem I've had is that if you got a heavy liner underneath and try to one finger grab the clutch the mitt part can block it from fully engaging.so no problem getting your finger caught under the lever?
the shell is cotton on the back of the glove, so I’m going to wax It for water-proofing.
mad far as protective property. Well, the palm is leather.More than half good
that’s why I’m trying to figure out if I can get myself to hold the bar with index finger and grab three fingers of brake and, because the clutch goes all the way, full four of clutch.The only problem I've had is …try to one finger grab the clutch the mitt part can block it from fully engaging.
