Hello everyone. I have a 2004 DL-650 and am looking for some guidance.
I just replaced the battery and changed the oil after the bike was sitting for a few weeks (due to the battery being at the end of it's life). After I finished the tune up, I went to take it out for a ride and promptly stalled as soon as I dropped it into gear. Seems like the clutch will not release.
Not sure what the issue might be, but it still occurs after taking off the sprocket cover and ensuring that everything is clean and non-fouled. I also ensured that the clutch cable and lever are both adjusted and functioning properly. Any thoughts on what might cause a stuck clutch? Broken springs, or maybe a broken clutch pushrod? Any chance it could just be two plates sticking together?
Just wondering where I should look first and if I should pull the case.
Thanks for the tips!
