Strom Trooper banner
1 - 4 of 4 Posts
Hello everyone, hopefully my last question for awhile... I've got the bike pretty much back together now. I reattached the clutch cable and mechanism and noticed that it wasn't engaging the clutch. I'm guessing the issue is with the "pin" that I'm assuming is supposed to depress the clutch inside the engine isn't engaging for some reason? I'm at a bit of a loss here. I'm so close to being done and frustrated that I can't take her out for a ride. I did manage to start the engine even without the clutch working and she's running well and charging. (Original problem was a burned out stator.)
What am I doing wrong now?!
I circled the "pin" in red.
the clutch actuator has a spiral gear on it, sometimes when you take it out it separates and you can get it a notch or two off. Just separate it and try the next notch, if that doesn't work take it back off and try the next notch.
Thanks, I'll give that a try. Should I be able to push that "pin" in with my hands? Because I can't get it to depress with just my fingers.
1 - 4 of 4 Posts
