So, engine off, transmission in 1st, clutch lever out, will the bike roll forward when you push it?
Same, clutch lever all the way in, will the bike roll forward? If it rolls, how far can you slowly let the clutch out until you feel the bike starting to be harder to push, just the beginning of any drag?
Engine running, you're riding, clutch lever squeezed in only a half-inch, will the clutch begin to slip? (This is the correct cable length adjustment.)
There's a youtube video of a guy lubing his chain with the bike on the center stand and the engine turning the rear wheel. It cuts his fingers off when he gets them too close. You should be able to lube the chain fine with the engine off and the transmission in neutral.
