Yesterday was my first decent day of riding this season (my 2nd season as a rider). Rode about 120 miles on country roads on my '15 Wee (3K miles), with a fair amount of shifting. All is well accept I feel that the tension to pull in the clutch lever feels tight. Perhaps I just need to get used to it again after a long winter break. The free play appears to be set correctly.
Does anyone know if the degree of tension to pull in the clutch lever can be adjusted? Hoping for a solution that would require less effort and reduce a sore hand.
Thanks!
I would take the clutch lever off, clean it all down and apply a smear of grease to all touching parts. Remove the lock nut first, and then the shoulder bolt. Ensure that the lever is not jammed in the perch. On reassembly stop as soon as the shoulder bolt takes up all slack and then use the lock nut to secure it. Cables these days have a Teflon inner but a few drops of WD40 will not harm anything.
Take off the countershaft cover and check and grease the cable nipple. While you are there you may as well check for a 1/4 turn of slack in the actuator as described in MAZ4ME's link.
I recommend taking as much slack from the throttle cable as reasonably possible to ease on/off throttle abruptness, but start the motor and check that full lock to lock does not activate the throttle before riding.
I wouldn't use WD40 on the cable as it gunks up after drying out. I remove the cable from the lever, take a piece of duct tape and wrap it about half way leaving half past the housing to make a well, position cable with the end upward and fill the well with ATF and let it sit till the ATF goes in the cable. ATF won't hurt the cable liner and won't gunk up or dry out. Been using this method for years and it works.
