Your clutch pressure plate has moved too far toward the outside of the bike. Probably happened when you were working on the slave cylinder.
There will be some space between the plates, there is a steel disc between each of the fiber plates you see when looking into the oil fill hole. When correct very little of the clutch pressure plate will be outside the edge of the clutch basket fingers. I am betting yours is about halfway out, and if so that is what the problem is. What happens is the plate gets pushed out just enough that it can get out of its grooves and catches on the inner hub slots. Some have had success taking a screwdriver and rotating the pressure plate slightly which allows it to seat back into its grooves. Otherwise you will have to pull the clutch cover and loosen the pressure plate bolts to get it back in place.
