1 - 10 of 10 Posts
Short story... I need to drive three hours to fix my bike this Saturday. My clutch cable broke 150 miles from home on the other side of a 9000-ft elevation mountain pass hiway.
Long story is here...
http://www.stromtrooper.com/showthread.php?t=39709
SOOO, what advice can you gurus give me, more specifically...
1) What tools do I NEED to have with me that I may not think of taking?
2) Is a replacement cable really only about $16? That's what the parts fiche at Bike Bandit says.
3) Is the cable something a dealer typically has in-stock or should I try and get it online so I KNOW it will be in my hands before I leave Friday night? Anything else I need to buy? I am going to try and get my hands on a service manual, but I'm not sure I can before I leave Friday evening.
4) Any "gotchas" that I should be aware of? Special hints for making the job smoother and easier? Do I need to take the cowling off? If you can't tell, I've never done this before... lol.
Thanks for any help you can give. Hopefully it will be a fun way to spend my 40th birthday and not turn into a disaster. :p
I'd make a wise crack about having a hydraulic clutch on a real bike, but I suppose that would be inappropriate and would probably cause the clutch cables on my other bikes to break.
lol poser
I found a couple of good write-ups on VSRI. Looks much easier than I thought it would be.
I read one write-up (only one) that said they lubed the heck out of the cable before they put it in??? I thought these were self-lubing cables and didn't need that sort of thing? Or do you self-lube it upon install and then forget about it?
Not sure I ever heard of a self lubing cable. AFAIK all cables, clutch or throttle, need regular lubrication.
I thought the strom cables were teflon lined and didn't require lubrication.
SS
SS
That's my understanding too. I was under the impression that lubing your cables actually shortens their life.
I got the new cable in. Was MUCH easier than I anticipated. Zip-tied the new cable to the clutch end of the old one and pulled it through. I did have to loosen the cable guide directly under the gas tank, but other than that it was painless. Got the thing hooked-up, handle end first... was able to do it on the clutch end without having to take off the whole assembly that the cable attatches to which most write-ups said I would need to do. All told, took only about 45 minutes (would have been shorter but had to put the handguard back on too).
Thanks to all those who offered to lend a hand.
Guy at the local dealership was warning me to make sure I had the tools and stuff needed to remove the tank, etc. Heh, I'll go back and tell him just how easy it was without having to do that.
ONE question remains unanswered!
... SOOO, what advice can you gurus give me, more specifically...
2) ...
There is one important tool that Mrs. Suzuki left out of our tool kits.
To remove the front wheel, you need an Allen key 12 mm in diameter. If you do not have one with you, you can cobble one up by extracting two 12 mm nuts and a bolt they fit, then turning the nuts together, but that is a poor substitute for the proper tool.
Keith
Sequel: I was 500 miles from home, with 42000 miles on the odometer, and my clutch cable was, I thought, on its very last legs. I minimized use of the clutch and carefully shifted without the clutch, probably squeezing the lever no more than 30 times on the ride home.
I did not take the risk of breaking the cable while investigating or trying to adjust it.
I ordered a new clutch cable, then investigated. Yes, some strands were broken, so the new cable was needed, but in fact the cable was way out of adjustment. Perhaps the adjuster and its keeper became loose when I parked with the left side a tad too close to the pavement.
I would have had a less stressful ride home if I had investigated and adjusted. Foo.
K
1 - 10 of 10 Posts
