I have approx 12000 mi on my bike and adjusted the clutch pushrod per the mainual. Before doing do, I set the cable adjuster all the way in at the lever as directed. After adjusting push rod, I attempted to adjust the cable via the adjusters under the sprocket cover so that about 1/2" play at the lever. The problem (maybe not) is that the adjuster is almost fully at the extreme "tightening" end - and I still have more than 1/2" free play at the lever. The only way to get tighter is at the lever adjustment. I was wondering if this is normal?
Thanks for any info.
