1 - 19 of 19 Posts
Hello,
I'm close to buying a new 2015 DL 1000.. Just curious if there's things I should know about the bike .. Harley sold today !
Was looking at the Super T until I noticed the pegs are welded to the frame..so no chance lowering them ? Duh
Was there ever an issue with clutch baskets on the new ones ?
ECU in Canada
Wiring harness
Thanks in advance
Gobear
There is nothing unique about the Canadian model so I'm moving the thread. There is a recall on the wiring harness so any affected models will have the wiring harness fixed before it is sold. The clutch baskets are fine when new but may develop chudder with use. A fix from Werks Parts (see our supporters) will handle that if it develops. The ECU has caused lean spots in some specimens but a test ride should establish if the particular model you want has an issue. Some Euro models are getting new ECUs if they show problems and that fix may extend to North America in the future, but it isn't happening much now if at all.
I would be concerned with the constant ear to ear grin you will have after riding your new dl1000. Get used to weird looks from people who wonder what the hell "that guy" is so happy about???:grin2:
One thing to compare is how many used S1's for sale VS used V2's. That speaks volumes. Why sell your used bike when there is nothing better? It is a great bike.
Hello,
ECU in Canada
Wiring harness
Thanks in advance
Gobear
If you feel like a drive to Kingston you are welcome to come take mine for a spin.
You're in a V-strom forum...I'm pretty sure no one will tell you not to buy it. I own one myself and have nothing bad to say about it.
This is a little misleading.....there are lots of used Teneres for sale because Yamaha has already made some significant updates to the Gen 1 bike. Lots of Tenere owners are selling to upgrade to the Gen 2. Pre 2013 is Gen 1, after are Gen 2. They are dirt cheap right now........like around $9,000 (new) for pre 2013. The pegs can be lowered easily, they sell an offset peg and the shifter and brake are adjustable. Both Gen 1 and 2 are fine bikes and the changes included electronic adjustable suspension and factory cruise control.
That said, the new V2 is a great bike also.
You owe it to yourself to research and try both. While they are both Japanese ADV bikes, they are quite different. Each has some unique attributes.
As to your question about V2 problems....yes there are some niggles, you will find info on them here. But the Tenere has a few also. ADVrider is probably the best place to get an impartial idea of the bikes. I had a hard time deciding between the two bikes myself.
Happy motoring.
Reactions: Toto and Big B
I also sold my Harley for a v2. Haha. New left over as well. I can honestly give you a impartial view.
The s10 is heavier and slower. And uglier. I love Yamaha but they messed up on that one. If I were going to buy a different adv bike it would probably be the triumph. It's the closest in weight and power.
Pros.. Fast. Real fast. The motor is 42cc bigger than the v1. It's a dohc instead of sohc. It has 4 plugs and burns fuel better than the v1. It is lighter than the v1. If you get one you could just get the adv model with hand guards and bags and that belly plate that is trash and needs replaced. But the right bag is very lacking with this huge cutout for the pipe. The windshield is good but isn't perfect.. Aftermarket a are cheap but the ratcheting shield mount is awesome. The lights work great.. It handles like a dream. 3 way front suspension controls and 2 way rear are very good. The stock seat is actually very comfortable. Bars are in a great spot. Pegs are very good in the stock position. It's as if Suzuki took the Ktm1290 and copied it. All around a perfect motorcycle for the most part. If you like wheelies this is the bike for you. It gets all its power at about 4K and keeps it. The adv model crash bars are perfect. The display is easy to read and switching between tc settings is smooth. The tc setting 1 is the least intrusive it will let you be aggressive and will lift the front tire a few inches and set it back down. Level 2 cuts power and is more intrusive but you can't feel it working as much.. But you can feel is being slower. And off.. Just prepare for hard acceleration in 1st gear to keep the front wheel in the air a couple feet if wanted.
Cons.. It has a couple. Don't blip the throttle.. It sometimes will die out. The bag as mentioned. The windshield could be 2 inches taller. The fairing design around the headlight is shit.. All the wind comes around the headlight follows the body line and slams you right in the chest. (I have designed my own fix for this) the lower cowl on the adv model as stated is shit and For show only. The throttle is very touchy. It's either on or off.. You will get used to slowly turning it though. I can't think of anything else bad or annoying. For the off-road guys you can't turn off the abs..
I can't think of a reason for you not to buy it. Go get it.
I'd have to say that a pretty big majority of us have had no issues at all with stalling,throttle problems, scary noises or other running issues. I'm sure those things are really frustrating for the folks that have them but your odds of getting one with no problems should be pretty good.
I am insulted....the Tenere is UGLY?:frown2: I guess beauty is in the eyes of the beholder......:confused:
From another ex-harley guy and beakfree rider in Kentucky:wink2:
BTW, the old Vee was also DOHC. The old and new engines are very similar, but the new V2 is improved in several ways...unfortunately they did not fix the clutch completely or idle hammer either as it is still showing up in some bikes. That said, my V1 chuddered and idle hammered all the way to over 105,000 miles and is still on the road making ugly noises.
Reactions: Big B
I noticed today that the v1 was dohc.. I was mistaken.
And mine does a clutch out very light chatter with less than 1000 miles on it. Oh well. Sorry about the s10... That and the Africa twin to me are hideous haha. I'll take beak all day over no beak and funny lights.
Sorry for multi posts.. My clutch out chatter is only in N at a stand still. I pull the clutch in and it stops.
My chain is easier to lube>:)
My projector beam lights will cook a hot dog:kiss:
Discussion Starter #16
Ok so the Harley's gone...
My reluctance stems from siting on the bike in the show room and having a really good hard look at it.. What was Suzuki thinking with the brake peddle .. It looks like a cheap piece of cast that wasn't finished?
And the front under the windshield looks toy like.. Maybe there's a reflector option to stick to all those protruding plastic bumps!
The foot pegs suck big time for an ADV .. Do it right Suzuki put none slip pegs..and while you at it fix the windshield and the fuel metering...no I didn't notice the fuel issue while sitting on the bike
Why not make the stock seat adjustable..like Yamaha and BMW..now I have to spend another $200.00 so I can be comfortable ?
Side Luggage you can't even put a helmet in ?
Do I sound negative .. No I'm just tired of having to spend the other side of 20 k to get a quality product..even my humble DR650 looks more the part..and it isn't perfect..brand new out of the box ..it had an off ideal stumble built in to meet emissions
The Yamaha is too wide at the front ..IMHO
Yes you fix all of the above..just not sure why Suzuki didn't ..j
Just buy a new KTM 1190 or 1290........yup your gonna pay, but after owning a Harley you should be used to that. ;) No bike is perfect for everyone out of the box, and that is why there are options out there to make modifications.
Discussion Starter #19 (Edited)
I've all ready ridden it..so I'm speaking from experience and over 40 years of riding and probably just as many bikes..
The trouble is .. We the consumer enable manufacturers by continuing to support them even if their products have lots of issues.
Based on the fact there are still 2014 left over ..I guess we're starting to question things a little more closely.
And I'm not a Harley rider ... I'm a motorcyclist
1 - 19 of 19 Posts
