Not that I disagree, but I don't think you need a tire gauge to tell you if your pressure is appropriate for a dirt or gravel road; it'll either feel right or it won't ... it's on pavement that it's much harder to tell. Just my limited experience.Overinflated on dirt roads just might get you killed.
Front tire -- I knew it was wrong all right, both on wet pavement and on the dirt. After a few hours of being scared half to death at relatively high speed on dirt roads, I borrowed a gauge from one of my buddies and threw my new gauge into the woods somewhere in Quebec.Not that I disagree, but I don't think you need a tire gauge to tell you if your pressure is appropriate for a dirt or gravel road; it'll either feel right or it won't ... it's on pavement that it's much harder to tell. Just my limited experience.
My experience has been that the gauges built into compressors and pumps are the least useful. I ignore them.this spring I got a new compressor, it came with a guage that when reading 36 lbs the real pressure was about 26 max,,, I tossed that one .
Bur should we do that when we are probably 50%-100% heavier than factory riders?If the tires are the same size and type as the factory tires, then go with the vehicle specification.
Unless you buy a gauge that has NIST certs with it, any gauge that is purchased is subject to being wrong. Even the NIST gauges haved to be check periodially to confirm accuracy.I dug through my stuff and came up with about a half-dozen gauges, both dial and pencil type. All were very close except one that was sent to the trash. My new Milton inflator's gauge was 3 psi higher than all the rest. I asked Milton about that, and they said that it was within spec for that 10 psi to 150 psi gauge. Milton said that it wasn't able to be field calibrated, but one of these day's I'll see for myself.
Make your own gauge. A 0-60 psi (you want the intended reading to be about the middle of the gauge), 1-1/2" diameter, 2% accuracy pressure gauge is about $10. Add a tire chuck that best fits your valve stem positions, and you have an accurate gauge.
I've been in more than a few stores where the thermometers for sale all have different readings. Why anyone would buy one of them, I don't know.but how do I know if they are accurate or how accurate they are?
