1 - 1 of 1 Posts
Was setting up some extensions on throttle bodies so it's easy to do a sync... both the caps were cracked and cut right through(2004). Surprised it didn't cause a vacuum leak on computer. :yikes:
Take 2 min and check yours... u might be losing some power. Did fresh sparks and the external fuel filter mod... so can't tell u for sure it helped but I'm guessing it did. They are on the underside of the throttle bodies... easiest approach is to pull gas tank(easy on naked). :p
Here is link to nipple locations.
http://home.comcast.net/~terrygrush/Throttle Body Sync.pdf
1 - 1 of 1 Posts
