In English
Thank you for the welcome;
Well, my motorcycle is a vstrom dl650 k7 (2007).
For no reason one day I tried to turn on the motorcycle and noticed that when I opened the switch the CHEC warning did not turn off, but I said to start and the bike turned on normally, so I decided to use it with that fault.
While I was on the move, the fault appeared intermittently, until one day it didn't disappear anymore.
The motorcycle is working properly.
now clean all connectors, knob, d sensor
My reply:
Normally the CHEC light does not turn on. It only does so when it detects a fault, usually the kill switch or side stand.
With the CHEC light on the ignition, fuel pump and the motor should not work, meaning that some part of the wiring must have been altered.
Do you know of any wiring modifications?
Normalmente la luz de CHEC no se enciende. Solo lo hace cuando detecta una falla, generalmente el interruptor de apagado o el caballete lateral. Con la luz de CHEC encendida, la bomba de combustible y el motor no deberían funcionar, lo que significa que alguna parte del cableado debe haberse alterado. ¿Conoces alguna modificación de cableado?
