A while back I was having problems when starting the bike, when already warmed up, it would seem to die out, like the power went dead for a second, then crank up. Would always cold start with no power lag or other problems however
Had the battery replaced 2 years ago, off the shelf at a batteries plus store, AGM replacement. At the time they said it did not need to be charged prior to using it, so it went right into the bike..
Since the replacement, the same problem has recurred intermittently. If it had been sitting in the store for a few months and I didn't fully charge it before using it, could that cause premature failure? I did take it back to have it load and they said it was fine.
The bike is now sitting at a supermarket parking lot, battery completely dead.. I had stopped to pick up something for the wife, "no good deed goes unpunished" as they say....At least I have roadside at $10 for the year
If it did require a full charge prior to use, you would think a store that sells nothing but batteries would have known that, right?
Update>> Just got the bike back home. 13 resting volts, drops to zero when you turn the key on
