1 - 3 of 3 Posts
You will likely have to take the tank off. If the front plug is in the same place as on the wee, you will need to loosen the radiator in order to gain access. Be careful not to tighten them too much
Tank most certainly must come off for air filter, and yes the radiator off makes accessing the front plug super easy "your coolant needs changed anyways". ;) Do a search function, you will see some great pics and write ups.
1 - 3 of 3 Posts
