okay, so i cleaned, adjusted, and then lubed my chain yesterday. this morning when i took off to work i noticed my chain was making a "whizzing" noise, didn't sound terrible, but i have never heard this before?
when i adjusted the chain i checked slack in the middle of the of the chain between the front and rear sprockets (~14 inches from center of rear axle) and i checked it and adjusted it on both the side stand and rear wheel stand (measurement was roughly the same). i don't think i got the chain too tight, i set the calipers i have to 1.2" and used that as my guide. also after checking the tightness i looked down my chain and sprockets to make sure that they were aligned, and they looked fine to me, i also used the tick marks near the axle as a reference.
and for other informational purposes i used an o-ring safe motorcycle chain cleaner, then i lubed it up with the dupont multi-use teflon lube in the blue can.
anyone know if this is normal for a clean chain? what else should i check?
oh and i also checked the chain stretch, and it was under the limit.
thanks!
thanks!
