1 - 3 of 3 Posts
I just installed a new 525 chain from Blair onto my K8 ABS Wee.
15/47
In this combo, the chain is at about 2/3 of adjustment brand new.
With a 14/47 I'm pretty sure it would be at the limit, especially when it wears.
But - I can't take another link out and have it fit with the 15/47.
What are other peoples experiences with new chains / tension / length?
Thanx
Paul
I've never used more than the distance between two marks over the entire life of a chain. The change in distance over 20 links between a new and a stretched beyond limit chain is only 0.07".
With my worn chain (tight links, some stretch), ok rear sprocket and a new 14t - I could not set correct tension. 15t was ok.
I'm starting to think you can't run the same length chain and swap between 14t and 15t front sprockets.
Paul
1 - 3 of 3 Posts
