1 - 12 of 12 Posts
Has anyone changed or demounted/mounted their center stand springs? How did you do it? I struggled and fought to engage the larger spring, but I am simply not strong enough. I tried using a brake spring tool, and that did not work either.
After half an hour of battle, I took a lesson from my brake spring tool (automotive) and made the tool pictured below. It is simply a piece of drill rod that I had on hand, heated one end and hammered it flat, then ground the rough marks off it and used a right angle grinder with a cut-off wheel to make the notch. I hooked the slot over the spring and used the crossbar on the OEM center stand as a fulcrum. Once it was close, channel lock pliers pushed the open end of the spring's hook over the centerstand anchor point and I was home free. The small spring is much easier.
I lowered my bike and had to shorten the center stand - I could not get the bike up on it alone, and two people worked hard to get it there. The whole idea for me is to have the stand in case of a flat - and then the rear of the bike would be a few inches lower yet, so shortening it was in the cards. The tool is about 8" long overall, I cut the length so that it would fit with maybe 1/2"clearance to the ground.
But, absent such a tool, is there a secret other than brute strength?
You need to use leverage rather than outright strength. I make a small loop of fencing wire and attach it to the bottom hook, through which I use a heavy bladed screwdriver (almost a small crowbar) and find a place on the main stand to use as a fulcrum. As you get past 90 degrees with your lever the springs hook closes up and in towards the hook.
It is still a struggle, and I always have to adjust the size of the loop a few times. Note that the shortest distance between the two pegs is when the stand is in its up position and so I block up the stand.
I used the "cord tied to the rear wheel" trick: took about 10 seconds to tie the cord to the wheel and one second to pop the spring onto the post.
I use my homemade spring puller tool. Worked great on the center stand springs.
Sent from my Pixel using Tapatalk
This was timely. I struggled for over an hour on those springs and then I realized that someone would have already solved this problem. Lo and behold, I found this recent thread and the subsequent links. Used the string theory. Took a couple of attempts on the large spring, but it worked. You have to be careful to place the small spring on the inside of the peg and get that connected. Then do the large spring. If you don’t get the small spring on the inside of the peg, the large spring gets twisted up by trying to put it on the inside.
Thanks.
Frankly. I have a buddy who is strong enough to do the spring thing. It seems pretty dangerous, no matter what, I worry about his eyes, he gets right down in there. I would pull the center stand without this gu around. LOL
When i installed my new factory center stand last week I just used a long skinny screwdriver to pull and hook the inner and then outer spring.
1 - 12 of 12 Posts
