Changing the oil from the factory installed side stand is easy...you don't need a center stand for that. Just place the drain pan under the drain plug and filter and have at it. After the oil quits dripping out I tip the bike to an upright position and then lean it over against the stand again...this isn't necessary but it does get a little more used oil out.
Chain maintenance is also easy from the side stand. Put the bike on a flat hard surface. Place a floor jack under the edge of the rear link opposite the side stand and jack it up just enough to lift the rear tire off the ground. I was a little concerned the first time I tried it but my bike is very stable when done correctly and there isn't much extra load placed on the side stand.
